14 years agoADC output from LVDS deserializer.
I have a an ADC sampling at 40 MHz, and it output LVDS signal, so i have to deserialize it using my DE2-115, but i am having trouble with the deserialized signal (shown in the picture), it should display a pure sine wave. I have no idea what are the possible solution. I am using the lvds_rx block provided from megawizard. I have not set the .SDC file yet, you think that might solve the problem? Please comment.. regards, Michael33 Replies
The AdcOut[11] is wrong. I am sure. The AdcOut[9] is wrong, maybe. So check all wire length.
Sorry, the AdcOut[10] is wrong.
I do not know how to upload picture.
--- Quote Start --- is it called DPA (dynamic shift alignment) ? how do we activate this function? cause last time i check with altlvds_rx in Megawizard, it was grayed out, and someone in the forum said DPA is not available to Cyclone series. --- Quote End --- DPA is a feature of hardware LVDS_RX blocks in Stratix and Arria FPGA family and allows an automatic sampling phase correction of individual bits under some prerequisites. It's in fact not available with Cyclone FPGAs. Dynamic phase shift is a basic feature of the PLL blocks since Cyclone III. It can be used to achieve a DPA-like functionality with the LVDS PLL, but not for individual bits. Unlike with hardware DPA, that can be simply enabled in the MegaWizard, you have to design the phase shift state machine and signal edge detector yourself. @eRen: Your point isn't clear. There's no doubt about wrong bits in the ADC data. The original poster also reported, that he was able to fix the problem. Length mismatch can't explain the failure of individual bits in this case, because it's a serial LVDS data transmission over a single differential pair, so all bits undergo the same delay. - Altera_Forum
What FvW said is reasonable. Maybe add a NOT gate in outclock will resovle the problem.
What kind of the ADC? AFE5851?AFE5801? The mismatch may between the clock signal and data signal, or the lvds p and lvds n. - Altera_Forum
From the AdcOut picture, the spurs cover all over sina signal. The big spurs are caused by the Msb bit, the small spurs caused by the Lsb bit. So, I guess the possiblity of mismatch is very high.
If the mismatch is between the clock and data signals, you can try the method:
HSMC_RX_D_P -> PLL( the output frequency is same as the input, adjusting the phase ) -> LVDS12401 -> DCFIFO - Altera_Forum
--- Quote Start --- Dynamic phase shift is a basic feature of the PLL blocks since Cyclone III. It can be used to achieve a DPA-like functionality with the LVDS PLL, but not for individual bits. Unlike with hardware DPA, that can be simply enabled in the MegaWizard, you have to design the phase shift state machine and signal edge detector yourself. --- Quote End --- well.. its good to know it can be done.. but i have absolutely no idea how to do that. Michael - Altera_Forum
--- Quote Start --- If the mismatch is between the clock and data signals, you can try the method: HSMC_RX_D_P -> PLL( the output frequency is same as the input, adjusting the phase ) -> LVDS12401 -> DCFIFO --- Quote End --- we already talked about that in this thread.. making a timing constraint file to do that phase shifting "expectation".. in order to tell fpga what to expect from ADC.. how much degree of phase shift is data with respect to clock. Michael
