A3C* BSDL updates available?
There are several of the A3CZ, A3CU and A3CV* families which are fail compilation with syntax errors on pins duplicated (usually K24 and K25). and then a most have errors in their use of port_grouping.
Are there updates available?
Regars,
Tom
iBSDL - Intellitech BSDL Compiler Version 14.25
Copyright (C) 1993-2026 Intellitech Corp. All rights reserved.
ERROR: Device package pin mappings: Duplicate pin id K24 ( IEEE Std 1149.1 Rule B.8.7.3 a).
ERROR: Device package pin mappings: Duplicate pin id K25 ( IEEE Std 1149.1 Rule B.8.7.3 a).
INFO: Associated Port REFCLK_GTSL1A_RX_n with function OBSERVE_ONLY in a boundary register
is legal - 1149.1 Rule B.8.8.3 d overridden
INFO: Associated Port GTSL1A_RX_CH3n with function OBSERVE_ONLY in a boundary register
INFO: Associated Port GTSL1A_RX_CH2n with function OBSERVE_ONLY in a boundary register
INFO: Associated Port GTSL1A_RX_CH0n with function OBSERVE_ONLY in a boundary register
INFO: Associated Port GTSL1A_RX_CH1n with function OBSERVE_ONLY in a boundary register
ERROR: Associated port GTSL1A_TX_CH3n was found in a PORT_GROUPING attribute. Associated ports, the second
port in a PORT_GROUPING statement can only be in the boundary register when the function
in the BOUNDARY_REGISTER attribute is OBSERVE_ONLY. One solution would be to remove GTSL1A_TX_CH3n
from the PORT_GROUPING attribute. ( IEEE Std 1149.1 Rule B.8.8.3 d)
ERROR: Associated port GTSL1A_TX_CH2n was found in a PORT_GROUPING attribute. Associated ports, the second
in the BOUNDARY_REGISTER attribute is OBSERVE_ONLY. One solution would be to remove GTSL1A_TX_CH2n
ERROR: Associated port GTSL1A_TX_CH1n was found in a PORT_GROUPING attribute. Associated ports, the second
in the BOUNDARY_REGISTER attribute is OBSERVE_ONLY. One solution would be to remove GTSL1A_TX_CH1n
ERROR: Associated port GTSL1A_TX_CH0n was found in a PORT_GROUPING attribute. Associated ports, the second
in the BOUNDARY_REGISTER attribute is OBSERVE_ONLY. One solution would be to remove GTSL1A_TX_CH0n
The compile failed.
- tomachie
your response perhaps shows a misunderstanding, that there is some separate BSDL for 1149.1 vs. 1149.6. This may directly identify that there is a general knowledge gap around these standards which prevent providing customers useful information in IEEE compliant form. IEEE 1149.6 is a layer on top of 1149.1. The rules for BSDL come from 1149.1 and then extensions are added to support 1149.6. The very BSDLs you point to are the ones which are failing compilation. Altera, nor any other vendor, offer separate BSDLs one for 1149.1 and one for 1149.6 so the idea "these 1149.6 might work" is incorrect. This IS the compilation of a3cu100bb23c.bsdl it has no other form provided by Altera.
iBSDL - Intellitech BSDL Compiler Version 14.22
ERROR: Associated port CDRCLKOUT_GTSL1A_CH2n was found in a PORT_GROUPING attribute. Associated ports, the second
in the BOUNDARY_REGISTER attribute is OBSERVE_ONLY. One solution would be to remove CDRCLKOUT_GTSL1A_CH2n
ERROR: Associated port REFCLK_GTSL1A_CH1n was found in a PORT_GROUPING attribute. Associated ports, the second
in the BOUNDARY_REGISTER attribute is OBSERVE_ONLY. One solution would be to remove REFCLK_GTSL1A_CH1n
- Ash_R_Altera
I got a response back on the internal ticket that I raised. Team has generated the models internally and will be publishing them soon, in couple of weeks. Please watch out the page in a week or so. Thanks for your patience till then.
- Ash_R_Altera
Thanks for the clarification. I will raise an internal bug for the topic.
- Ash_R_Altera
Just checking, were you able to use the IEEE 1149.6 compliant models?
- Ash_R_Altera
Referring to below two links, I don't find IEEE 1149.1 compliant models for Agilex 3.
https://www.altera.com/design/devices/resources/models/bsdl
Can you set the tool to check IEEE 1149.6 compliancy instead?
