14 years agoa simple code showing a latch in quartus II?
Hi i am working in system verilog and a simple code like
always_ff @ (posedge clk , negedge rst_n) begin if (rst_n==1'b1) begin x<=a; elseif (i==1'b1) begin x<=x+1'b1; end end i am not using the exact name but the code is exactly the same where i is an input pin to the module. its showing 2 warnings Warning (13004): Presettable and clearable registers converted to equivalent circuits with latches. Registers power-up to an undefined state, and DEVCLRn places the registers in an undefined state. and Warning (335093): Timing Analysis is analyzing one or more combinational loops as latches for x these warning are coming. Thanks2 Replies
Yes i was facing an additional delay when i checked the timing reports.
Thanks for the reason... - Altera_Forum
You can expect this warning for all recent FPGA families that don't have both asynchronous set and reset provided with their registers. They need to implement a rather complex circuit with a XORed data path on both sides of the register and a latch holding the asynchronous preset value. Besides the reported restrictions, the construct involves additional delay.
The preferred solution is to avoid an asynchronous variable preset.
