16 years ago
A little help with verilog please.
wire ts_irig_wire;
reg  ts_irig;
        always @(posedge clk_c0)
        begin
            ts_irig <= {bit_num_cont6,bit_num_cont5,bit_num_cont4,bit_num_cont3,bit_num_cont2,bit_num_cont1};
        end
assign ts_irig_wire = ts_irig;
Hello to everyone! This code is giving me this error:
Error (10133): Verilog HDL Expression error at fpga.v(226): illegal part select of unpacked array "ts_irig_wire"
I can't figure out why, anyone could give me a hand please?
THanks
    Yes, simply declare the wire in the same way you declared the reg.
    Thanks, so a declaration of
    wire [23:0] wirename is a 24 bits bus
    and a declaration of
    wire wirename[23:0] consists in 24 wires of 1 bit?
    instead of
    wire ts_irig_wire[23:0];
    you should write
    wire [23:0] ts_irig_wire;
    like you have done with the register declaration.
    there is a difference where you place the brackets [] as FvM explained.
    wire [N:0] wirename [0:M];
    defines an array with a width of [N:0] and [0:M] elements
    in your case it has a width of 1 and [23:0] elements
    so you have defined an array.
    wire ts_irig_wire[23:0] is an array, not a vector definition.
