15 years ago7segment decoder
This is my code for a 7segment decoder, but I get an error!
package sevenDecoderLib is type sevenSegment is array(7 downto 1) of bit; variable segment: sevenSegment; function integer2SevenSegment(i: in integer range 0 to 15) return sevenSegment; end package sevenDecoderLib; package body sevenDecoderLib is function integer2SevenSegment(i: in integer range 0 to 15) return sevenSegment is begin case i is when 0=> segment := "1111100"; when 1=> segment := "0110000"; when 2=> segment := "1101001"; when 3=> segment := "1111001"; when 4=> segment := "0110011"; when 5=> segment := "1011011"; when 6=> segment := "1011111"; when 7=> segment := "1110000"; when 8=> segment := "1111111"; when 9=> segment := "1111011"; when 10=>segment := "1110111"; when 11=>segment := "0011111"; when 12=>segment := "1001110"; when 13=>segment := "0111101"; when 14=>segment := "1001111"; when 15=>segment := "1000111"; end case; return segment; end integer2SevenSegment; end sevenDecoderLib; Library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; Library work; use work.sevenDecoderLib.all; entity Lab5 is port( a: in integer range 0 to 15; output: out std_logic_vector(7 downto 0) ); end entity; architecture behave of Lab5 is begin a:=1; output := integer2SevenSegment(a); end behave;5 Replies
redefine sevenSegment as a std_logic vector. The bit type is hardly ever used:
VHDL is a strongly typed language, and won't automatically convert types for you. The string is by default a std_logic_vector IIRC, and as your variable is an array of bits you would need to convert the vector first. It is easier to declare your variable as a std_logic_vector instead.subtype sevenSegment is std_logic_vector(7 downto 1); - Altera_Forum
Okay it made sense,
but I still have this syntax error: Error (10511): VHDL Qualified Expression error at Lab5.vhd(51): integer2SevenSegment type specified in Qualified Expression must match std_logic_vector type that is implied for expression by context as the output would be a signal should I then change my function to sth like this: function integer2SevenSegment(i: in integer range 0 to 15) return sevenSegment is variable segment: sevensegment; begin case i is when 0=> segment <= "1111100"; - Altera_Forum
you cannot initialise A in here because it is an input, you need to initilaise it at it's source. Also, all input/outputs are already signals.
Thank You for replying,
at this case if output <= integer2SevenSegment(a); then I've to declare the output as a signal or am I wrong? I am very new to VHDL. And if I want to initialize the value of a from the codes not the graphs as a number between 0-15 how can I fix that if I can't use this code a<=5; - Altera_Forum
The variable declaration needs to be put in the function body, not in the package declaration. Also you cannot assign a value to an input port (in your case 'a'). Furthermore you need to use '<=' to assign a value to a signal or an output port.
package sevenDecoderLib is type sevenSegment is array(7 downto 1) of bit; function integer2SevenSegment(i: in integer range 0 to 15) return sevenSegment; end package sevenDecoderLib; package body sevenDecoderLib is function integer2SevenSegment(i: in integer range 0 to 15) return sevenSegment is variable segment: sevenSegment; begin case i is when 0=> segment := "1111100"; when 1=> segment := "0110000"; when 2=> segment := "1101001"; when 3=> segment := "1111001"; when 4=> segment := "0110011"; when 5=> segment := "1011011"; when 6=> segment := "1011111"; when 7=> segment := "1110000"; when 8=> segment := "1111111"; when 9=> segment := "1111011"; when 10=>segment := "1110111"; when 11=>segment := "0011111"; when 12=>segment := "1001110"; when 13=>segment := "0111101"; when 14=>segment := "1001111"; when 15=>segment := "1000111"; end case; return segment; end integer2SevenSegment; end sevenDecoderLib; Library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; Library work; use work.sevenDecoderLib.all; entity Lab5 is port ( a : in integer range 0 to 15; output : out std_logic_vector(7 downto 0) ); end entity; architecture behave of Lab5 is begin -- a := 1 ; output <= integer2SevenSegment(a); end behave;
