15 years ago7segment decoder
This is my code for a 7segment decoder, but I get an error! package sevenDecoderLib is type sevenSegment is array(7 downto 1) of bit; variable segment: sevenSegment; function ...
15 years agoThe variable declaration needs to be put in the function body, not in the package declaration. Also you cannot assign a value to an input port (in your case 'a'). Furthermore you need to use '<=' to assign a value to a signal or an output port.
function integer2SevenSegment(i: in integer range 0 to 15) return sevenSegment;
end package sevenDecoderLib;
package body sevenDecoderLib is
sevenSegment is
begin
case i is
when 0=> segment := "1111100";
when 1=> segment := "0110000";
when 2=> segment := "1101001";
when 3=> segment := "1111001";
when 4=> segment := "0110011";
when 5=> segment := "1011011";
when 6=> segment := "1011111";
when 7=> segment := "1110000";
when 8=> segment := "1111111";
when 9=> segment := "1111011";
when 10=>segment := "1110111";
when 11=>segment := "0011111";
when 12=>segment := "1001110";
when 13=>segment := "0111101";
when 14=>segment := "1001111";
when 15=>segment := "1000111";
end case;
return segment;
end integer2SevenSegment;
end sevenDecoderLib;
Library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
Library work;
use work.sevenDecoderLib.all;
entity Lab5 is
port (
a : in integer range 0 to 15;
output : out std_logic_vector(7 downto 0)
end entity;
architecture behave of Lab5 is
begin
-- a := 1 ;
output <= integer2SevenSegment(a);
end behave;
