15 years ago7segment decoder
This is my code for a 7segment decoder, but I get an error! package sevenDecoderLib is type sevenSegment is array(7 downto 1) of bit; variable segment: sevenSegment; function ...
15 years agoThank You for replying,
at this case if output <= integer2SevenSegment(a); then I've to declare the output as a signal or am I wrong? I am very new to VHDL. And if I want to initialize the value of a from the codes not the graphs as a number between 0-15 how can I fix that if I can't use this code a<=5;
