GTese's avatar
GTese
6 years ago
Why the following error has occurred when I try to program FPGA? I use Altera board DE1_SoC. OS Ubuntu 18.04 and IntelFPGA 18.1 standard version.
aocl program: Running reprogram from /home/root/opencl_arm32_rte/board/c5soc/arn
altera_fpga_manager ff706000.fpgamgr: timeout
  • Hi ,
    If you can try the compilation on Ubuntu 16.04 or 18.04 that would be helpful , since the issues of compatibility of GLIBC can be avoided.
    You can also check which version of GLIBC is currently installed in your system to cross verify.
    Thanks and Regards
    Anil
  • AnilErinch_A_Intel's avatar
    AnilErinch_A_Intel
    Hi
    can you confirm that The MSEL settings for your board is correctly configured.
    Thanks and Regards
    Anil
    • GTese's avatar
      GTese
      I have conform the MSEL setting to pp32 bits.​
    • GTese's avatar
      GTese
      I use URTA USB for reprogram the DE1_SoC board via minicom. So, How I can reduce the frequency of URTA or it not?
      I generated .aocx file by using offline compiler.
    AnilErinch_A_Intel
    If you are using an SD card with pre-built image and using minicom to login to it please let us know the same.
    In that case you can try creating the SD card image with lower JTAG frequency configuration.
    Also please try multiple OpenCL examples , like helloworld and simple programs, and let us know whether the issue is still coming.
    Thanks and Regards
    Anil
  • GTese's avatar
    GTese
    Thank you!!!
    I have no idea creating SD card image with lower JTAG frequency configuration.
    If you have some note on this idea please share with me.
    • GTese's avatar
      GTese
      Thank you very much!! I have great respect you.
      I have some issue.
      After I program FPGA with .aocx file it now successful configured. However, when I try to running host code the following error is generated. So,how I can fix it?
      /run: /lib/libm.so.6: version `GLIBC_2.27' not found (required by ./run)
      ./run: /lib/libm.so.6: version `GLIBC_2.29' not found (required by ./run)
      ./run: /lib/libc.so.6: version `GLIBC_2.17' not found (required by ./run)
      ./run: /lib/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by ./run)
      ./run: /lib/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by ./run)
      unfortunately, Upgrade OS Ubuntu 18.04 to Ubuntu 20.04.
      Please help me!!!
      Warm regrades!!
      Guta
    AnilErinch_A_Intel
    Hi ,
    Thanks and Regards
    Anil
    • GTese's avatar
      GTese
      THankyou for reply!
