Why the following error has occurred when I try to program FPGA? I use Altera board DE1_SoC. OS Ubuntu 18.04 and IntelFPGA 18.1 standard version.
- 6 years ago
Hi ,
If you can try the compilation on Ubuntu 16.04 or 18.04 that would be helpful , since the issues of compatibility of GLIBC can be avoided.
You can also check which version of GLIBC is currently installed in your system to cross verify.
Thanks and Regards
Anil
Hi
Please set the MSEL to 01010
There is a similar issue observed in the following link
https://software.intel.com/en-us/forums/opencl/topic/850597
as mentioned there , can you refer to
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd06242013_922.html
and try to reduce the JTAG frequency and let us know the results.
Thanks and Regards
Anil
I use URTA USB for reprogram the DE1_SoC board via minicom. So, How I can reduce the frequency of URTA or it not?
I generated .aocx file by using offline compiler.
