Why the following error has occurred when I try to program FPGA? I use Altera board DE1_SoC. OS Ubuntu 18.04 and IntelFPGA 18.1 standard version.
- 6 years ago
Hi ,
If you can try the compilation on Ubuntu 16.04 or 18.04 that would be helpful , since the issues of compatibility of GLIBC can be avoided.
You can also check which version of GLIBC is currently installed in your system to cross verify.
Thanks and Regards
Anil
Hi
You can check the following link on SD card image creation.
https://rocketboards.org/foswiki/Documentation/BuildingBootloader#Cyclone_V_SoC_and_Arria_V_SoC
Also if possible please use Ubuntu 16.04 and let us know , whether same issue exists.
The following guide will be helpful to get info about jtagconfig
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_usb_blstr.pdf
Thanks and Regards
Anil
Thank you very much!! I have great respect you.
I have some issue.
After I program FPGA with .aocx file it now successful configured. However, when I try to running host code the following error is generated. So,how I can fix it?
/run: /lib/libm.so.6: version `GLIBC_2.27' not found (required by ./run)
./run: /lib/libm.so.6: version `GLIBC_2.29' not found (required by ./run)
./run: /lib/libc.so.6: version `GLIBC_2.17' not found (required by ./run)
./run: /lib/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by ./run)
./run: /lib/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by ./run)
unfortunately, Upgrade OS Ubuntu 18.04 to Ubuntu 20.04.
Please help me!!!
Warm regrades!!
Guta
