GTese
6 years agoWhy the following error has occurred when I try to program FPGA? I use Altera board DE1_SoC. OS Ubuntu 18.04 and IntelFPGA 18.1 standard version.
aocl program: Running reprogram from /home/root/opencl_arm32_rte/board/c5soc/arn altera_fpga_manager ff706000.fpgamgr: timeout
- 6 years ago
Hi ,
If you can try the compilation on Ubuntu 16.04 or 18.04 that would be helpful , since the issues of compatibility of GLIBC can be avoided.
You can also check which version of GLIBC is currently installed in your system to cross verify.
Thanks and Regards
Anil
AnilErinch_A_Intel
6 years agoHi,
If you are using an SD card with pre-built image and using minicom to login to it please let us know the same.
In that case you can try creating the SD card image with lower JTAG frequency configuration.
Also please try multiple OpenCL examples , like helloworld and simple programs, and let us know whether the issue is still coming.
Thanks and Regards
Anil
