MMinu3's avatar
MMinu3
6 years ago
Problem erasing EPCQ flash memory on INTEL Cyclone evaluation board with Generic Serial Flash Interface Intel running on NIOS II
As mentioned above, I'm not able to erase Flash Memory (neither sectors, sub-sectors, or bulk) using the Generic Serial Flash Interface Intel running on NIOS II: only with "Quartus programmer" I can.
In the attached image you can see the waveforms on memory pins (clock, data in and CS): nothing changes if the first interval of "Status read" is stretched up to several milliseconds.
Sometimes, the memory locations seems to be "partially erased" (meaning that the content changes, but not to 0xFF), sometime the content doesn't change...
What do you suggest me?
Thanks in advance for your support.
Maurizio
