MMinu3
6 years agoProblem erasing EPCQ flash memory on INTEL Cyclone evaluation board with Generic Serial Flash Interface Intel running on NIOS II
As mentioned above, I'm not able to erase Flash Memory (neither sectors, sub-sectors, or bulk) using the Generic Serial Flash Interface Intel running on NIOS II: only with "Quartus programmer" I can....
MMinu3
6 years agoHi,
yes I tried the suggestions mentioned in the link, and the FPGA and the peripheral are clocked at 75MHz while the SPI clock to memory is about 5MHz (CLKDIV = 0x10)
All other parameters are on default value.
Thank you
Maurizio
