Power failure pointed to this EP4CGX50CF2317N
Encountered power failure in field and customer wanted request FA on the faulty device. Please help to review and provide ERMA #.
Failed: Field failure (RMA return)
Failure :
SN ACPZ9396---Unable to power up port – DC :1613
SN ACPG6599—Unable on line(Power failure) – DC 1537
MPN : EP4CGX50CF2317N
PN : JNTG-310-053350
Qty for FA : 2 pcs
Supplier : Altera.
Desc: Altera Cyclone EPACGX50CF23I7N FPGA
- Zawani_M_Intel
Do you suspect any failed pins? If yes, can you listed the pin name here?
Wania
- SOtha1
Failed part removed and no specific pin was suspected failing .
The failed board has been isolated, passed after replacement with new EP4CGX50CF2317N.
Hence, customer want this unit to send back to Intel for further FA. Please help to share the ERMA #.
- SOtha1
Hi Wani,
Any update on this?
We seek your prompt respond here since Juniper is now chasing for the FA result. This failure observed on our RMA board, return from field and wanted to understand the failure root cause. Please help to look into thus request and provide the ERMA # accordingly.
