Power failure pointed to this EP4CGX50CF2317N
Do you suspect any failed pins? If yes, can you listed the pin name here?
Wania
Failed part removed and no specific pin was suspected failing .
The failed board has been isolated, passed after replacement with new EP4CGX50CF2317N.
Hence, customer want this unit to send back to Intel for further FA. Please help to share the ERMA #.
- SOtha15 years ago
Hi Wani,
Any update on this?
We seek your prompt respond here since Juniper is now chasing for the FA result. This failure observed on our RMA board, return from field and wanted to understand the failure root cause. Please help to look into thus request and provide the ERMA # accordingly.
- SOtha15 years ago
Hi Zawani,
Kindly support on this FA request asap. Your prompt support is required for this case.
- SOtha15 years ago
Hi Zawani,
Can we know what is the stopper for you to handle this case? We have been waiting for long time.
If there are any other thing that you need us to provide, please let us know. We will consult with Juniper for this.
