drbarryh's avatar
drbarryh
9 months ago
MAX10 10M50 Development KIT Triple Speed Ethernet problem
Greetings to all of the ALTERA Experts,
I have been trying to get a Gigabit Ethernet interface working on an ALTERA MAX10 10M50-C Development kit and keep hitting a bit of a brick wall when tying to communicate with the MARVEL ALASKA 88E1111 PHY. It does not appear to respond correctly when i try to read for example the PHY ID register (address x02) which should respond with the value 0x041 but instead sends back 0x7fff.
I am using a System Verilog HDL approach to both instantiate the ALTERA Triple speed IP core in MAC only mode, with 2K word FIFOs, and full duplex 10/100/1000. The IP is set to work in Gigabit mode. When i connect the board to a windows 10 PC using an Ethernet cable i can see the Yellow LED lit up on the Dev KITS PHY connector and when i test the connection on the windows 10 PC it says it is up and connected.
But when i try to send any Ethernet packets (i am using IPV4 + UDP as packet payload) nothing gets through to the PC. I have verified this as well using WIRESHARK which shows me no ethernet frames are coming in from the MAX10 Dev kits end.
I have set the Triple speed Ethernet IP cores mac0/mac1 register to this random value: 48'h321C23174ACB
I think this is OK and what the Triple Speed Ethernet User Guide says. Please correct me if my thinking is wrong though ?
Questions:
a) Does any body know of any errata / bugs with this Development KIT OR with the MARVELL PHY ?
b) Can anybody point me to a Git Hub which has a known working example using this ALTERA Dev Kit along with this MARVELL PHY ? This can use either a HDL approach (like i am trying to use here) or a NIOSV softcore processor approach.
c) The MAX10 Dev Kit has 2 Ethernet PHYS. A and B. I think that the MAX10 10M50-C Dev Kit sets its A MARVELL PHY Address to 0x0 and its B side MARVELL PHY Address to 0x1 BUT its not easy i found to figure out the PHY addresses. If somebody can please show me how to properly derive the PHY ADDRESSES for both the MARVELL 88E1111 devices for PHY A (ETHERNET A)  and PHY B (ETHERNET B) on the MAX10 10M50-C Dev Kit Board Schematic) i will be very grateful !
Thanks for any help,
Dr Barry H
  • Hello Dr Barry,
    For clarification, is this different query or it's related to TSE reference design? If its related to the reference design , can I close this and provide support in the earlier Forum thread that we're working on currently?
    Pavee
    • drbarryh's avatar
      drbarryh
      Hi Pavee, Yes this is an earlier but related query about the TSE and the MAX10 problems i was seeing with tht reference designs. You can close it down now and lets stick with the other thread for progression to a solution.
      Cheers, Dr Barry H
