Iw1esu's avatar
Iw1esu
6 months ago
AXC3000 Agilex 3 board
for a new design I'm starting to use an evaluation board from Arrow Electronics, (but designed by trenz electronics) with Agilex 3
https://github.com/ArrowElectronics/Agilex-3/wiki/Agilex-3-AXC3000-Development-Platform
This board has an Hyperam W957D8NBRA4I installed but the Nios V example design uses only internal RAM.
Anyone knows if the IP to use this ram is free into quartus or is necessary to acquire a license?
  • AdzimZM_Altera's avatar
    AdzimZM_Altera
    Hi Iw1esu ,
    I think Hyperam component may use with a third party IP and might require a license.
    For the third party IP, you may need to check the vendor directly for the license.
    Maybe you can reach out to Arrow first to check for the resources of the evaluation board on using the Hyperam.
    Adzim
  • Iw1esu's avatar
    Iw1esu
    Hi, I'm waiting to receive 2 AXC3000 board to try some test with a minimal nios V system and basic code running on hyperam.
    If an IP will be necessary and cost some keuros this will be a big problem for my design based (by now) on this board. Arrow demo design runs from internal ram, strange to have an hyperram on board without using it, talking about an evaluation board
