DK-DEV-AGI027RES Install Package
I'd like to download an old outdated install package. It is for DK-DEV-AGI027RES.
The link was removed a while back. Can someone at Altera please find the install package for me?
A .qsf file with all the pinouts (e.g. golden_top.qsf in the install package) defined would work too.
- sstrell
Do you mean from here?: https://www.altera.com/products/devkit/a1jui0000049utmmam/agilex-7-fpga-i-series-development-kit-2x-r-tile-and-1x-f-tile
ES is engineering sample but usually you can use the final installers for ES boards unless noted.
- JYau1
Those installers are for Dev kits using "Power Solution 2". I need one for "Power Solution 1" which is the rev A. of the board. So only a installer package from around 2020-2022 may work.
- FakhrulA_altera
Hi JYau1,
I'm attaching the installer package for DK-DEV-AGI027RES. Please try to download and check it.
Update: Apparently, I couldn't attach it here because of the size limitation. I will send to your email separately.
Fakhrul
- liuzhaode
Fakhrul,
May attach the factory recovery part or mail me the whole file? I need the .sof and .pof file to recover my board which FPGA is lost in the JTAG chain.
Zhaode
