DK-DEV-AGI027RES Install Package
Do you mean from here?: https://www.altera.com/products/devkit/a1jui0000049utmmam/agilex-7-fpga-i-series-development-kit-2x-r-tile-and-1x-f-tile
ES is engineering sample but usually you can use the final installers for ES boards unless noted.
Those installers are for Dev kits using "Power Solution 2". I need one for "Power Solution 1" which is the rev A. of the board. So only a installer package from around 2020-2022 may work.
- FakhrulA_altera10 months ago
Hi JYau1,
I'm attaching the installer package for DK-DEV-AGI027RES. Please try to download and check it.
Update: Apparently, I couldn't attach it here because of the size limitation. I will send to your email separately.
Fakhrul
- omer_be4 months ago
hi FakhruIA_altera
can you please upload the installer package of the DK-DEV-AGI027RES.
i cant find it.
omer
- TorsteinH4 months ago
Hi FakhrulA_altera,
I am also interested in the installer package for DK-DEV-AGI027RES, could you please send it to me as well?
Torstein
Hi JYau1,
Apologies for the delay in sending the file. I couldn’t attach it via email due to size limitations. I realized you only need the QSF file, so I’ve converted it to .txt format since the system doesn’t allow .qsf attachments.
Please find the file below.
Fakhrul - Ash_R_Altera4 months ago
Attaching the BTS for the devkit.
