aWild8's avatar
aWild8
7 years ago
Logic levels on Pins from the Factory
What logic levels do the pins on the 10M50DCF484I7C float to from the factory?
aka, when I plug this chip into my PCB for the first time before programming it are the pins floating, pulled low, pulled high. Is it a strong pull or a weak pull?
I have had issues in the past with the floating logic levels destroying parts of my circuit because the FPGA is not there to pull signals high.
