aWild8
7 years agoLogic levels on Pins from the Factory
What logic levels do the pins on the 10M50DCF484I7C float to from the factory? aka, when I plug this chip into my PCB for the first time before programming it are the pins floating, pulled low, pull...
SreekumarR_G_Intel
7 years agoFlow chart page no : 28/67 below link information about the Configuration Sequence for Intel MAX 10 Devices and each stage IO lines state too.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_config.pdf
Thank you ,
Sree
