aWild8
7 years agoLogic levels on Pins from the Factory
What logic levels do the pins on the 10M50DCF484I7C float to from the factory? aka, when I plug this chip into my PCB for the first time before programming it are the pins floating, pulled low, pull...
SreekumarR_G_Intel
7 years agoAre you asking state of the Max 10 FPGA IO at reset state ? if yes , answer to your questions is Tri-State.
Thank you,
Sree
- aWild87 years ago
Not the logic levels at the reset state. but the logic levels on the pins right when I take the chip out of the box and power it on.
If the chip is in a reset state straight out of the box then this does answer the question.
