Is there a known good project i can use as a baseline for a PCIe project on a Cyclone 10GX development board?
I'm currently experimenting on the qts_pcie_sft project.
The unzipped qts_pcie_sft project doesn't compile on 19.2. Error on Board Trace Model setting on some pins i can't identify. Couldn't find any info on the error codes.
Tried 17.1 because the source files appears to have been developed using version 17 but Quartus quits/stops when i click on compile right after finishing IP Generation during compile process.
I'm using uneditted sourcefiles. So i'm stuck at the moment. I need to prove first if the source files are working before i can add on our custom codes. Thanks!
Apologies for delay
We have to remove remove Board trace models.
Please remove below lines from .qsf file and run full compilation.
set_global_assignment -name OUTPUT_IO_TIMING_NEAR_END_VMEAS "HALF VCCIO" -rise
set_global_assignment -name OUTPUT_IO_TIMING_NEAR_END_VMEAS "HALF VCCIO" -fall
set_global_assignment -name OUTPUT_IO_TIMING_FAR_END_VMEAS "HALF SIGNAL SWING" -rise
set_global_assignment -name OUTPUT_IO_TIMING_FAR_END_VMEAS "HALF SIGNAL SWING" -fall
Checked with Quartus pro 19.1
Anand
- JBayl
Issue with long folder/file path. Reduced the number of folders and compilation proceeded partially but still with errors.
- AnandRaj_S_Intel
Please user reference design from below link
https://forums.intel.com/s/createarticlepage?articleid=a3g0P0000005QyOQAU&action=view
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_c5_pcie.pdf
https://forums.intel.com/s/createarticlepage?articleid=a3g0P0000005RSyQAM&action=view
Anand
- JBayl
Hi Anand,
We will be using Cyclone 10 to replace our existing Cyclone V based product. I was hoping for a starting project for a Cyclone 10GX development board.
Update:
- on 17.1, regenerating all the QSYS files helped a bit, compilation reached 35% before Quartus hangs.
Thanks!
- JBayl
Hi Anand,
This might be the same issue. See link
I curently have it @ f:/sandbox/qts_pcie_sft/qts_pcie_sfp. I'll reduce it to just 1 directory tomorrow and see if it compiles.
- JBayl
Reducing project directory tree to f:/qts_pcie... didn't help. 17.1 compilation still hangs while 19.2 compilation still results with these errors:
Error(329006): Some pins have illegal board trace models.
Error(20403): Global setting for OUTPUT_IO_TIMING_NEAR_END_VMEAS is not supported. Please use this setting with pin assignments.
Error(20403): Global setting for OUTPUT_IO_TIMING_FAR_END_VMEAS is not supported. Please use this setting with pin assignments.
How can i fix these fitting errors?
A fresh download of the Cyclone 10 GX development board collateral which contains the qts_pcie example project resulted in the same compilation issues. Is there an upgraded/fixed project?
In case it matters, i'm using a Windows 10 Pro 64 bit.
- AnandRaj_S_Intel
Hi Joel,
Yes, i have faced same issue in compiling using Quartus pro 19.1. let me check and come back.
Please try design from design store.
https://fpgacloud.intel.com/devstore/platform/?acds_version=any&ip_core=PCIExpress&board=102
Anand
- AnandRaj_S_Intel
Apologies for delay
Anand
- JBayl
That worked! Thanks Anand!
