Is there a known good project i can use as a baseline for a PCIe project on a Cyclone 10GX development board?
- 6 years ago
Apologies for delay
We have to remove remove Board trace models.
Please remove below lines from .qsf file and run full compilation.
set_global_assignment -name OUTPUT_IO_TIMING_NEAR_END_VMEAS "HALF VCCIO" -rise
set_global_assignment -name OUTPUT_IO_TIMING_NEAR_END_VMEAS "HALF VCCIO" -fall
set_global_assignment -name OUTPUT_IO_TIMING_FAR_END_VMEAS "HALF SIGNAL SWING" -rise
set_global_assignment -name OUTPUT_IO_TIMING_FAR_END_VMEAS "HALF SIGNAL SWING" -fall
Checked with Quartus pro 19.1
Anand
Reducing project directory tree to f:/qts_pcie... didn't help. 17.1 compilation still hangs while 19.2 compilation still results with these errors:
Error(329006): Some pins have illegal board trace models.
Error(20403): Global setting for OUTPUT_IO_TIMING_NEAR_END_VMEAS is not supported. Please use this setting with pin assignments.
Error(20403): Global setting for OUTPUT_IO_TIMING_FAR_END_VMEAS is not supported. Please use this setting with pin assignments.
How can i fix these fitting errors?
A fresh download of the Cyclone 10 GX development board collateral which contains the qts_pcie example project resulted in the same compilation issues. Is there an upgraded/fixed project?
In case it matters, i'm using a Windows 10 Pro 64 bit.
