JBayl
6 years agoIs there a known good project i can use as a baseline for a PCIe project on a Cyclone 10GX development board?
I'm currently experimenting on the qts_pcie_sft project. The unzipped qts_pcie_sft project doesn't compile on 19.2. Error on Board Trace Model setting on some pins i can't identify. Couldn't find a...
- 6 years ago
Apologies for delay
We have to remove remove Board trace models.
Please remove below lines from .qsf file and run full compilation.
set_global_assignment -name OUTPUT_IO_TIMING_NEAR_END_VMEAS "HALF VCCIO" -rise
set_global_assignment -name OUTPUT_IO_TIMING_NEAR_END_VMEAS "HALF VCCIO" -fall
set_global_assignment -name OUTPUT_IO_TIMING_FAR_END_VMEAS "HALF SIGNAL SWING" -rise
set_global_assignment -name OUTPUT_IO_TIMING_FAR_END_VMEAS "HALF SIGNAL SWING" -fall
Checked with Quartus pro 19.1
Anand
JBayl
6 years agoThat worked! Thanks Anand!
