Intel Arria10 SoC Dev kit, PC unable to scan board via PCIe
I am using Intel's Arria10 SoC Dev kit. I loaded the PCIe design example from the IP catalog. I was able to program the board ok. I attached the board to my PC via a PCIe cable. The PC is unable to recognize the board. I tried this board on another PC and it came up ok. What could be the cause that my PC is unable to recognize it? How can I debug this?
Lakshmi
- SengKok_L_Intel
Hi Lakshmi, I'm assuming that you program the FPGA and then restart the PC without power down the FPGA. Please do let me know if this is not the case. To understand the problem further, could you please add ltssm signal tap and capture the behavior? Besides, if the refclk of FPGA is coming from the host, then you have also need to check if the clock is stable. Regards -SK- LSant1
Yes, I programmed the FPGA but did not restart the PC. But I tried restarting the PC for a different reason and found the PC could not reboot when the FPGA board was powered up.
- SengKok_L_Intel
What is the difference between the working PC and non working PC? Does the PCIe refclk stable?
- LSant1
The issue turned out to be the PCIe slot. I had the adapter cable in a x4 slot. I moved it to a x16 slot and it was ok atleast for Gen2. The PC is PCIe Gen3 but the PC does not load the card under device manager for any Gen3 setting in the IP design example. Also, as you mentioned I had to restart the PC after programming to make the PC scan for the PCIe device. But my colleague is able to scan the device without restarting the PC. Both of us are using Windows 10 just different motherboards. Is there a BIOS setting for this? I couldn't find one but read there is a ACPI setting for hot plug. Do you know? Also, why is Gen3 not working? The other issue is the PCIe test is not passing (Altera_PCIe_Interop_Test from the IP core directory in Quartus folder). The test is able to get all the PCIe details like Hardware ID properly.
- LSant1
Looking at the video in the link, I am following all the steps as is. Still no luck with the hardware test. Will the example work for other design kits also by selecting "none" in the example design tab? The simulation itself works.
- LSant1
Under Device Manager, Altera PCI device, Events-Information, I see the message below even though the driver is shown to be installed and working properly. Why is that? I notice that x8 config doesn't work for Gen1 to 3. I think even x4 is not working but x2 is working. Could it have something to do with the message below?
Device PCI\VEN_1172&DEV_0000&SUBSYS_00000000&REV_00\4&2db3ecda&0&0008 requires further installation.
- LSant1
Actually that message was prior to the installation. Please ignore the last message about "requires further installation".
- SengKok_L_Intel
Just a quick check. When you generate the design example as none development kit. Did you tie the "npor" signal to 1?
Regards -SK
- LSant1
NPOR is tied to PERSTn. It works the same with NPOR tied to 1. We are actually seeing different behavior in 3 different PC's and with Intel SX SoC kit and ReflexCES Alaric kit. Attached is a compilation of the results. Can you please review and provide feedback?
Lakshmi
- SengKok_L_Intel
To understand the difference, we may need to know what is the difference in term of PERSTn timing, and when the refclk is start to stable for difference slot.
Regards -SK
