LSant1
7 years agoIntel Arria10 SoC Dev kit, PC unable to scan board via PCIe
I am using Intel's Arria10 SoC Dev kit. I loaded the PCIe design example from the IP catalog. I was able to program the board ok. I attached the board to my PC via a PCIe cable. The PC is unable to r...
SengKok_L_Intel
7 years agoJust a quick check. When you generate the design example as none development kit. Did you tie the "npor" signal to 1?
Regards -SK
LSant1
7 years agoNPOR is tied to PERSTn. It works the same with NPOR tied to 1. We are actually seeing different behavior in 3 different PC's and with Intel SX SoC kit and ReflexCES Alaric kit. Attached is a compilation of the results. Can you please review and provide feedback?
Lakshmi
