LSant1
7 years agoIntel Arria10 SoC Dev kit, PC unable to scan board via PCIe
I am using Intel's Arria10 SoC Dev kit. I loaded the PCIe design example from the IP catalog. I was able to program the board ok. I attached the board to my PC via a PCIe cable. The PC is unable to r...
LSant1
7 years agoLooking at the video in the link, I am following all the steps as is. Still no luck with the hardware test. Will the example work for other design kits also by selecting "none" in the example design tab? The simulation itself works.
- LSant17 years ago
Under Device Manager, Altera PCI device, Events-Information, I see the message below even though the driver is shown to be installed and working properly. Why is that? I notice that x8 config doesn't work for Gen1 to 3. I think even x4 is not working but x2 is working. Could it have something to do with the message below?
Device PCI\VEN_1172&DEV_0000&SUBSYS_00000000&REV_00\4&2db3ecda&0&0008 requires further installation.
