it depends on what is connected to the HSMC connector. Do you use a standard interface? (LVDS is just a voltage level)
yes, standard interface
what interface? what protocol? We can't help you without more details.
My project' application is in ultrasound area. High speed is necessary.
I will give the datas from an ultrasound kit (AFE5805 - Texas). It sends 12 bits serial in LVDS format, I transform them to parallel format and the Cyclone III Starter kit' job is receive and process the ultrasound signal. I use now the standard example for to write and to read in DDR-SDRAM memory, and the next step is add this IO. - Altera_Forum
So what you need is a component that does the serial-to-parallel conversion and present the data in a way that can be understood by the Nios CPU. I don't think that such a component already exists (but I could be wrong), so you'll probably have to create your own custom component.
I would recommend that this custom component presents the parallel data using the Avalon Stream protocol. It is very easy to implement, and you'll be able to use SOPC builder ready available components to handle the actual transfer to memory (a double clocked fifo and a sgdma, as an example). - Altera_Forum
Interesting...I can use this later.
I use now a kit ADSDESER (texas too) that converts serial to parallel. My first question is my easy: How I found the correct address of HSMC pins in a SOPC project, using GPIO for example ? I saw the system.h file, and I found the led_io and button_io only. I pretend read the ddr-sdram memory, and I would to see the result in a array of leds from hsmc output pins, not leds of the FPGA kit. - Altera_Forum
You need to add a PIO to your SOPC hardware project first, then update the top level design file to connect those to external pins, and then use the assignment editor to set the exact pin used for each signal. I would recommend to look at the board schematic rather than the documentation to find out which FPGA pin is connected to which pin on the HSMC connector. Altera's kit documentations are known to have a few mistakes in them.
With the new SOPC system, when you regenerate the system library you'll see your new PIO port in system.h I'm not sure that a PIO is the best solution though, it is rather slow. - Altera_Forum
Thank you Daixiwen,
I add the PIO in project. But the standard example doesn't have the top level design file (.bdf) I can't update this... Will I create a new file ? - Altera_Forum
No, I guess the top level file is a verilog file (.v extension). You can either edit that file or recreate everything in a .bdf file (but this last option will take some time...)
Thank you Daixiwen.
I add a GPIO (12 pins) in my project and modified the verilog file. The program has been successfully compiled. I do the pin assigment using the HSMC debug header. But, when I run the program in Nios, nothing happen in the output pins. (for example, I would to write 0x07 in the new GPIO) Aways the output pins are in high level (2.5V). Somebody can help me ?
