16 years agoHSMC interface IO in SOPC Builder
I have a Cyclone III Starter kit, and I want to write some datas in dr_sdram memory from HSMC IO. In SOPC Builder, how do I build this interface HSMC IO( LVDS format) ? Do I use the RapidIO m...
16 years agoYou need to add a PIO to your SOPC hardware project first, then update the top level design file to connect those to external pins, and then use the assignment editor to set the exact pin used for each signal. I would recommend to look at the board schematic rather than the documentation to find out which FPGA pin is connected to which pin on the HSMC connector. Altera's kit documentations are known to have a few mistakes in them.
With the new SOPC system, when you regenerate the system library you'll see your new PIO port in system.h I'm not sure that a PIO is the best solution though, it is rather slow.
