16 years agoHSMC interface IO in SOPC Builder
I have a Cyclone III Starter kit, and I want to write some datas in dr_sdram memory from HSMC IO. In SOPC Builder, how do I build this interface HSMC IO( LVDS format) ? Do I use the RapidIO m...
16 years agoMy project' application is in ultrasound area. High speed is necessary.
I will give the datas from an ultrasound kit (AFE5805 - Texas). It sends 12 bits serial in LVDS format, I transform them to parallel format and the Cyclone III Starter kit' job is receive and process the ultrasound signal. I use now the standard example for to write and to read in DDR-SDRAM memory, and the next step is add this IO.
