16 years agoHSMC interface IO in SOPC Builder
I have a Cyclone III Starter kit, and I want to write some datas in dr_sdram memory from HSMC IO. In SOPC Builder, how do I build this interface HSMC IO( LVDS format) ? Do I use the RapidIO m...
16 years agoInteresting...I can use this later.
I use now a kit ADSDESER (texas too) that converts serial to parallel. My first question is my easy: How I found the correct address of HSMC pins in a SOPC project, using GPIO for example ? I saw the system.h file, and I found the led_io and button_io only. I pretend read the ddr-sdram memory, and I would to see the result in a array of leds from hsmc output pins, not leds of the FPGA kit.
