16 years agoHSMC interface IO in SOPC Builder
I have a Cyclone III Starter kit, and I want to write some datas in dr_sdram memory from HSMC IO. In SOPC Builder, how do I build this interface HSMC IO( LVDS format) ? Do I use the RapidIO m...
16 years agoSo what you need is a component that does the serial-to-parallel conversion and present the data in a way that can be understood by the Nios CPU. I don't think that such a component already exists (but I could be wrong), so you'll probably have to create your own custom component.
I would recommend that this custom component presents the parallel data using the Avalon Stream protocol. It is very easy to implement, and you'll be able to use SOPC builder ready available components to handle the actual transfer to memory (a double clocked fifo and a sgdma, as an example).
