18 years agoHelp with Flash memory reading
hi,
I am new to digital design and FPGAs, and I am having trouble with the flash Memory on the Cyclone II development board. I am playing around with a simple (6502) based cpu core (actually the FPGA64 commodore 64 emulator) and I am trying to use the flashRAM as a ROM. The addresses to the flash are being held steady for over 400ns but all I get back on the flash data lines is $FE, which never changes even when the address changes. I have a simple wave file exported from Signal TapII, along with the vhdl of my memory manger code which I will try to attach as a zip file. I wrote a simple verilog program to increment the memory address of the flash every two clock cycles (using the 27mhz clock), and that seemed to work just fine. I have no idea why this code doesn't work. I would really appreciate some input as I have read plenty but this is my first time using real physical hardware and I am struggling :( Thanks Simon :)
