18 years agoHelp with Flash memory reading
hi, I am new to digital design and FPGAs, and I am having trouble with the flash Memory on the Cyclone II development board. I am playing around with a simple (6502) based cpu core (actual...
18 years agoI see several points why your code doesn't work as expected.
As a very general point, you can't write data to a flash memory by simply activating WE. Consult the flash datasheet at the DE2-70 system cd, you'll see that it's a rather complex action to write data to a flash. Basically it can be done in HDL code, but not in a few lines of code. As a more simple point, you're apparently using the flash control signals inverted. They are active low, shown by a# suffix in datasheet, but you set OE=1 and WE=0 and expect data at the data bus. I wonder if DE2-70 has suitable examples to evaluate such basic operations, but I'm not very familiar to the Terasic hardware or software.
