18 years agoHelp with Flash memory reading
hi, I am new to digital design and FPGAs, and I am having trouble with the flash Memory on the Cyclone II development board. I am playing around with a simple (6502) based cpu core (actual...
18 years agoyes sure... the flash datasheet says, for the write operation I need to set the pins as follow:
CE->0 OE->1 WE->0 WP->1 because I have nothing to protect RESET->1 for No Reset BYTE->1 for use the DATA -Bits DQ0 to DQ15 an these I have set... or what do you exactly mean? di I forgot something or missunderstand something? ok..."#" mean that they are active low...ok...that was something I don't know... so maybe the other pins are incorrect set...
