14 years agoFast & Large block data transfer over USB - DE1/DE2 ?
Hi I have a DE1 fpga module, which has a single USB port that seems to be dedicated to programming. Is it possible to use it to do fast, large block data transfers over the USB ?
I see quite a bit of discussion here in a similar vein, but do not see anything conclusive. I see the USB is connected to an FTDI FT245BL - this should be capable of 1M Byte / Sec, using their D2XX Drivers. It is then connected to an Altera MAX chip. Previous fpga modules that I have used with FTDI chips have been able to use the USB port for both programming and for data transfer. Or am I better to junk the DE1 board and buy a DE2 which I see has a second USB port ? cheers, Beau
