15 years agoFast & Large block data transfer over USB - DE1/DE2 ?
Hi I have a DE1 fpga module, which has a single USB port that seems to be dedicated to programming. Is it possible to use it to do fast, large block data transfers over the USB ? I see quite a ...
15 years ago --- Quote Start --- On the Morphic II the default reset seems to be a positive logic reset, I have to invert it as the logic I am importing my code from, an EZC1USB module, was a negative logic reset. --- Quote End --- Its just a pin, so its up to you to decide what it means :) --- Quote Start --- So indeed I can ignore it if I choose - never thought of that - though I do use it extensively to reset things before they run. --- Quote End --- I just meant ignore it while debugging. Resets are generally good to use. However, you should run them through a dual-DFF synchronizer prior to use, so that the synchronized reset deasserts synchronously. --- Quote Start --- How are your further thoughts on using the USB Blaster for data I/O coming on ? --- Quote End --- I haven't had a chance to work on it. I've been working on some TimeQuest timing analysis. Cheers, Dave
