15 years agoFast & Large block data transfer over USB - DE1/DE2 ?
Hi I have a DE1 fpga module, which has a single USB port that seems to be dedicated to programming. Is it possible to use it to do fast, large block data transfers over the USB ? I see quite a ...
15 years ago --- Quote Start --- The crucial commection for the reset is from the FT2232H pin 46 : BDBUS7, again labled Data3. --- Quote End --- If the FT2232H is being used to configure the Cyclone using passive serial communications with a 1-bit data width, then DATA[0] is the programming signal, and DATA[7:1] are available as control signals. If the FT2232H is being used to program the Cyclone using Fast passive parallel (FPP), then all DATA[7:0] bits are used during programming. Once the FPGA enters user-mode, the DATA pins can be configured as user-I/O. If this is the case in the Morph-IC-II, then the 8-bit bus from the FT2232 is a user-bus once the device is configured. Post the schematic and I'll look. Cheers, Dave
