14 years agoFast & Large block data transfer over USB - DE1/DE2 ?
Hi I have a DE1 fpga module, which has a single USB port that seems to be dedicated to programming. Is it possible to use it to do fast, large block data transfers over the USB ? I see quite a ...
14 years ago --- Quote Start --- Morphic II Schematic attached. --- Quote End --- DATA3 is just a data connection between the FT2232 and the FPGA. The FPGA can be configured to use it as a DEV_CLR signal, which is basically a reset, without actually having a reset in your top-level design entity. Personally, I'd configure the pin to be a general purpose I/O and treat it as an external reset control in the design. --- Quote Start --- One of the thing I am not clear about, is how to use the ftdi command ft_setbitmode. --- Quote End --- Set bitmode is used to change between MPSSE and regular modes. Check out the attached programmer for the Morph-IC. Cheers, Dave
