Example design: Agilex I-series devkit: intel_pcie_pio_1024 not converting TLP to Avalon-MM
Using Quartus Pro 22.1, I followed UG-20330 to generate from scratch the example design of the Agilex I-series Development Kit (ES).
1. Compiling, inserting the driver, the board is correctly recognized.
2. Compiling the user/example intel_fpga_pcie_link_test application
3. Running Automatic detection and 0: Link test - 100 writes and reads
********************************************************* Intel FPGA PCIe Link Test Version 2.0 0: Automatically select a device 1: Manually select a device ********************************************************* > 0 Opened a handle to BAR 0 of a device with BDF 0x100 ********************************************************* 0: Link test - 100 writes and reads 1: Write memory space 2: Read memory space 3: Write configuration space 4: Read configuration space 5: Change BAR for PIO 6: Change device 7: Enable SRIOV 8: Do a link test for every enabled virtual function belonging to the current device 9: Perform DMA 10: Quit program *********************************************************
I can see the TLP arriving in the FPGA but there is no Avalon-MM generated by the obscure intel_pcie_pio_1024 Intel IP core. Therefore the test fails.
And nothing for all the 1024clocks.
- alexislms
Contributor
And I am unable to simulate the design since there is an error that hasn't been answered for 1year: https://community.intel.com/t5/FPGA-Intellectual-Property/Agilex-FPGA-PCIe-Gen5-Example-Design-Simulation-Error/m-p/1328057#M24967
('rtile_s20_v0' file missing)
- Wincent_Altera
Thank you for reaching out.
Just to let you know that Intel has received your support request and I am assigned to work on it.
Allow me some time to look into your issue. I shall come back to you with the findings.
Thank you for your patience.
Wincent_C_Intel
- Wincent_Altera
Thanks for sharing with me your finding.
As investigated, the error can be due to a myriad of reasons and might be difficult to pinpoint exactly.
However, I've laid out some suggestions to help us narrow this down and further confirm the root cause.
- Did you try out the Avalon ST design ? Is it workable before moving to Avalon MM ?
- the user guide for R-tile PCIe
- https://www.intel.com/content/www/us/en/docs/programmable/683544/22-1-5-0-0/about-the-r-tile-streaming-fpga-ip-for.html
- How many clock cycle you are using ?
- As mention in the user guide page 4
- The current APPS component supports only single-cycle data transfers. Data transfers longer than one clock cycle are not supported
Let me know if you have any different thoughts. Hoping to hear back from you.
Wincent_C_Intel
- alexislms
Contributor
Please read again my first message.
1. I'm following the example design ug-20330 I mentioned, it's the same link.
2. As said, the simulation doesn't work.
Please confirm 1. and 2. work on your side. It isn't working for me and @TBalu (the link in my 2nd message).
If you don't see any issue on your side, please provide the Quartus Pro 22.1 archive project of the example design that works (hw + sim).
- Wincent_Altera
I do a quick check on the link in your 2nd message.
It is running simulation in Modelsim, are you getting the same error as well if running in Modelsim ?For your case, I don't see any things assign in the PIO_address.
If you want to read/write from the FPGA via PCIe to talk to another PCIe device my suggestion is as below
- Use the host PC to determine the PCIe address of the device you need to talk to.
- Configure the Qsys PCIe address remap registers so that it maps to the region of the device you want to control.
- Issue a read/write to the Avalon-MM slave interface of the Qsys PCIe component. That Avalon-MM transaction will map to a PCIe transaction that will then perform a read/write to the PCIe device.
Let me know if you have any other thoughts.
Wincent_C_Intel
- Wincent_Altera
I don’t have one I’ve personally tested for sure recently due to limited bandwidth, (will try to replicate if possible)
however, in general R-Tile is looking ok in 22.1 after referring to some internal resources.
We have a KDB that defines Known Issue focusing on 22.1, that for sure you should pay attention to:
Let me know if this works for you.
Wincent_C_Intel
- alexislms
Contributor
Hi @Wincent_Altera,
Thank you for the links, the `rtile_s20_v0` issue doesn't appear in the KDB 22.1 pro.
I don't have a Siemens* Questa* Advanced Simulator full version therefore I'll just wait for a new version.
I haven't done anything more than just following the exdes user guide and it doesn't work as shown in the screenshot, I give up.
Thank you again for the help, please feel free to close the ticket.
- Wincent_Altera
I manage to get a set of images based on 22.1 that are proven to be working on the devkit from engineering team.
Appreciate if you try it out, let me know if the issue is still happening. I shall help to escalate this into next level
Regards,Wincent_C_Intel
- alexislms
Contributor
