DE2-70 with D5M Camera
Hey,
I am working with the DE2-70 dev kit and the D5M camera. From my understanding, the demo for the camera uses both sdrams on the kit. I am trying to make it so the camera only uses one sdram. However, I haven't been successful with this thus far... The things that I have altered are in the Sdram_Control_4Port.v file:
// Internal Address & Length Control
always@(posedge CLK or negedge RESET_N)
begin
if(!RESET_N)
begin
rWR1_ADDR <= 0;
rWR2_ADDR <= 22'h200000;
rRD1_ADDR <= 0;
rRD2_ADDR <= 22'h200000;
rWR1_MAX_ADDR <= 1280*1024;
rWR2_MAX_ADDR <= 22'h200000+1280*1024;
rRD1_MAX_ADDR <= 1280*1024;
rRD2_MAX_ADDR <= 22'h200000+1280*1024;
rWR1_LENGTH <= 256;
rWR2_LENGTH <= 256;
rRD1_LENGTH <= 256;
rRD2_LENGTH <= 256;
end
and in the top file:
Sdram_Control_4Port u8 ( // HOST Side
.REF_CLK(iCLK_50),
.RESET_N(1'b1),
.CLK(sdram_ctrl_clk),
// FIFO Write Side 1
.WR1_DATA({sCCD_G,sCCD_B}),
.WR1(sCCD_DVAL),
.WR1_ADDR(0),
.WR1_MAX_ADDR(1280*1024),
.WR1_LENGTH(9'h100),
.WR1_LOAD(!DLY_RST_0),
.WR1_CLK(CCD_PIXCLK),
// FIFO Read Side 1
.RD1_DATA(Read_DATA2),
.RD1(Read),
.RD1_ADDR(0),
.RD1_MAX_ADDR(1280*1024),
.RD1_LENGTH(9'h100),
.RD1_LOAD(!DLY_RST_0),
.RD1_CLK(VGA_CTRL_CLK),
// FIFO Write Side 2
.WR2_DATA({sCCD_G, sCCD_R}),
.WR2(sCCD_DVAL),
.WR2_ADDR(22'h200000),
.WR2_MAX_ADDR(22'h200000+1280*1024),
.WR2_LENGTH(9'h100),
.WR2_LOAD(!DLY_RST_0),
.WR2_CLK(CCD_PIXCLK),
// FIFO Read Side 2
.RD2_DATA(Read_DATA1),
.RD2(Read),
.RD2_ADDR(22'h200000),
.RD2_MAX_ADDR(22'h200000+1280*1024),
.RD2_LENGTH(9'h100),
.RD2_LOAD(!DLY_RST_0),
.RD2_CLK(VGA_CTRL_CLK),
// SDRAM Side
.SA(oDRAM0_A),
.BA(oDRAM0_BA),
.CS_N(oDRAM0_CS_N),
.CKE(oDRAM0_CKE),
.RAS_N(oDRAM0_RAS_N),
.CAS_N(oDRAM0_CAS_N),
.WE_N(oDRAM0_WE_N),
.DQ(DRAM_DQ),
.DQM({oDRAM0_UDQM1,oDRAM0_LDQM0})
When I run it - the vga output is messed up.. I have looked at the older camera demo and they use a single sdram for it - I am not sure what I am doing wrong or haven't done. Thanks in advance..7 Replies
Hi there, I'm also beginner in Verilog. But looking at your program, the top file output for the sdram is only 16 bits. As I know, the vga code included in the demo needs 30 bits inputs per vga_ctrl_clk. I thing u have to convert the sdram_control_4port to make the output 32 bits. Or you can used the original code.
You can use 16 bits instead. Pulled this code from ousmu. It should work.
Sdram_Control_4Port u8 ( // HOST Side .REF_CLK(iCLK_50_2), .RESET_N(1'b1), .CLK(sdram_ctrl_clk), // FIFO Write Side 1 .WR1_DATA({drRed[11:7], drGreen[11:6], drBlue[11:7]}), .WR1(sCCD_DVAL), .WR1_ADDR(0), .WR1_MAX_ADDR(800*480), .WR1_LENGTH(9'h100), .WR1_LOAD(!DLY_RST_0), .WR1_CLK(CCD_PIXCLK), // FIFO Read Side 1 .RD1_DATA(Read_DATA3), .RD1(Read), .RD1_ADDR(0), .RD1_MAX_ADDR(800*480), .RD1_LENGTH(9'h100), .RD1_LOAD(!DLY_RST_0), .RD1_CLK(~ltm_nclk), // SDRAM Side .SA(oDRAM0_A[11:0]), .BA(oDRAM0_BA), .CS_N(oDRAM0_CS_N), .CKE(oDRAM0_CKE), .RAS_N(oDRAM0_RAS_N), .CAS_N(oDRAM0_CAS_N), .WE_N(oDRAM0_WE_N), .DQ(DRAM_DQ[15:0]), .DQM({oDRAM1_UDQM0,oDRAM0_LDQM0}) ); // add by oomusou for RGB16 assign Read_DATA4 = {Read_DATA3[10:6], Read_DATA3[4:0], 5'h00}; assign Read_DATA5 = {Read_DATA3[5:5], 4'h0, Read_DATA3[15:11], 5'h00}; - Altera_Forum
thanks for the replies...
I would prefer not to drop the image down to 16bit.. I think that the system is capable of coping with the full raw data - however I am pretty new to it all so was hoping that someone would advise on exactly where I was going wrong.. Again, thanks for the replies.. - Altera_Forum
Ok then, u do not understand what I mean right. Instead of using 1 sdram in the de2-70 board, the original code is used 2 sdram. If i'm not mistaken, the sdram controller assign as u8 and u9. FYI, the original code is used 2 sdram to be able read and write in 32 bits per cycle. So, if u want to convert the code by only using 1 sdram, u have to create new fifo controller with 30 bits in/out to be able load by vga. The clock for the buffer u create must be twice vga_ctrl_clk. Load 2 times to buffer from sdram then load by vga 1 times. If not, u wont be able to load 30 bits data to vga.
I hope this thread is still being viewed. I have a DE2 board and would like to know why the WR_LENGTH and RD_LENGTH are given the value 256? What is the use of the FIFO length here? - Altera_Forum
I've been working on D5M camera module for static image capturing using DE2 (not DE2-70) development board recently. The camera is integrated with nios2 system used for biometric image processing.
I made some changes to the image buffer (default SDRAM) because I needed it for program memory. So, i toss away the SDRAM design in D5M and used onchip memory as image buffer. However, the onchip memory on Cyclone II is too small. I can only capture 100x100 bayern pattern picture. :( I hope to port this design on larger FPGA, maybe DE3 board with Stratix III. - Altera_Forum
Can someone answer this please? I am interested in this question as well.
