16 years agoDE2-70 with D5M Camera
Hey, I am working with the DE2-70 dev kit and the D5M camera. From my understanding, the demo for the camera uses both sdrams on the kit. I am trying to make it so the camera only uses one sdra...
16 years agoYou can use 16 bits instead. Pulled this code from ousmu. It should work.
Sdram_Control_4Port u8 ( // HOST Side .REF_CLK(iCLK_50_2), .RESET_N(1'b1), .CLK(sdram_ctrl_clk), // FIFO Write Side 1 .WR1_DATA({drRed[11:7], drGreen[11:6], drBlue[11:7]}), .WR1(sCCD_DVAL), .WR1_ADDR(0), .WR1_MAX_ADDR(800*480), .WR1_LENGTH(9'h100), .WR1_LOAD(!DLY_RST_0), .WR1_CLK(CCD_PIXCLK), // FIFO Read Side 1 .RD1_DATA(Read_DATA3), .RD1(Read), .RD1_ADDR(0), .RD1_MAX_ADDR(800*480), .RD1_LENGTH(9'h100), .RD1_LOAD(!DLY_RST_0), .RD1_CLK(~ltm_nclk), // SDRAM Side .SA(oDRAM0_A[11:0]), .BA(oDRAM0_BA), .CS_N(oDRAM0_CS_N), .CKE(oDRAM0_CKE), .RAS_N(oDRAM0_RAS_N), .CAS_N(oDRAM0_CAS_N), .WE_N(oDRAM0_WE_N), .DQ(DRAM_DQ[15:0]), .DQM({oDRAM1_UDQM0,oDRAM0_LDQM0}) ); // add by oomusou for RGB16 assign Read_DATA4 = {Read_DATA3[10:6], Read_DATA3[4:0], 5'h00}; assign Read_DATA5 = {Read_DATA3[5:5], 4'h0, Read_DATA3[15:11], 5'h00};
