DDI Port mapping to FPGA Pins
For DDI port , should I need to use the transceiver pins(1C bank) or differential pins of 2L bank of 10AS016?
- CheepinC_altera
Dear Supritha, As I understand it, you seems to have some inquiries related to the A10 DDI port. To ensure we are on the same page, would you mind to further elaborate on the following: 1. What is the specific A10 SX part that you are using? 2. Are you using a devkit from Intel PSG or your own board? 3. Would you mind to further elaborate on the DDI port that you are referring to? Is it some interface availabe on the devkit? Some web reference or explanation on this interface will be helpful. 4. Please share with me also the specific data rate and requirement for the DDI port. Please let me know if there is any concern. Thank you. Best regards, Chee Pin- SB_S
Please see my answers as below -
SBS : Full Part number is 10AS016.
SBS : We are developing a new board with 10AS016.
SBS: Yes, this DDI port is available on the Dev Kit. DP_ML_LANE_N0 is the net name used in the Devkit.
SBS : if DDI port works at lower speed also is fine for us.
- CheepinC_altera
Thanks for your clarification on the net name in the A10 SOC devkit. As I understand it, the DDI port that you are referring are for Display Port. Based on my understanding with Display Port usage in A10 devices, generally they are connected to the high speed XCVR pins instead of GPIOs.
Chee Pin
- CheepinC_altera
Hi, as I checked with the A10 DisplayPort IP, the "Maximum lane count" support value of 1, 2 and 4. Therefore, there should be no issue to support 2 lanes.
