SB_S
7 years agoDDI Port mapping to FPGA Pins
For DDI port , should I need to use the transceiver pins(1C bank) or differential pins of 2L bank of 10AS016?
CheepinC_altera
7 years agoDear Supritha,
As I understand it, you seems to have some inquiries related to the A10 DDI port. To ensure we are on the same page, would you mind to further elaborate on the following:
1. What is the specific A10 SX part that you are using?
2. Are you using a devkit from Intel PSG or your own board?
3. Would you mind to further elaborate on the DDI port that you are referring to? Is it some interface availabe on the devkit? Some web reference or explanation on this interface will be helpful.
4. Please share with me also the specific data rate and requirement for the DDI port.
Chee Pin
- SB_S7 years ago
Please see my answers as below -
SBS : Full Part number is 10AS016.
SBS : We are developing a new board with 10AS016.
SBS: Yes, this DDI port is available on the Dev Kit. DP_ML_LANE_N0 is the net name used in the Devkit.
SBS : if DDI port works at lower speed also is fine for us.
