17 years agoAuto-Negociation fails between two Ethernet Marvell PHYs (88E1111)
I need to connect two PCIe development board via the Ethernet Marvell PHYs (88E1111) in order to validate an UDP solution (I'm using the TSE core). The thing is, Auto-Negociation between the two PHYs cannot complete, whereas it works fine connecting the two boards to an Ethernet switch. The link speed as to be 1000 Mbps. For programming the PHYs, here are the steps I'm performing: 1 - write 0x1A00 to PHY_0 register 9 (Manual Master, advertise 1000BASE-T full duplex) write 0x1200 to PHY_1 register 9 (Manual Slave, advertise 1000BASE-T full duplex) 2 - write 0x1340 to PHY_0 and PHY_1 register 0 (1000 Mbps, full duplex, enable Auto-Negociation, restart Auto-Negociation) 3 - Wait for Auto-Negociation to complete by checking the bit 5 of the status register (register 1). This bit is actually never asserted by either of the two PHYs. Is it possible to directly connect the two Marvell PHYs? Is there a way to skip Auto-Negociation for a 1000 Mbps solution? Thanks a lot Florian
