17 years agoAuto-Negociation fails between two Ethernet Marvell PHYs (88E1111)
Hello, I need to connect two PCIe development board via the Ethernet Marvell PHYs (88E1111) in order to validate an UDP solution (I'm using the TSE core). The thing is, Auto-Negociation between th...
15 years agoThen you should be able to disable autonegotiation and force a certain mode by using the MDIO registers 0 and 4. But you will also have to disable autonegotiation on the PC and set its mode manually
