17 years agoAuto-Negociation fails between two Ethernet Marvell PHYs (88E1111)
Hello, I need to connect two PCIe development board via the Ethernet Marvell PHYs (88E1111) in order to validate an UDP solution (I'm using the TSE core). The thing is, Auto-Negociation between th...
15 years agoI have fixed my PC for 100mbps & Full Duplex.
I checked changing ethernet cable and PC. When I connect to hub and auto-negotiation is enable 100mbps & Full duplex connection is established. But when I connect my custom board directly to PC via cross ethernet cable, 100mbps & Half duplex is established. I wish to have 100mbps & Full duplex connection establishment for my project. I want to disable auto-negotiation on my custom-board to avoid any uncertainity. I am using Triple-speed Ethernet MAC, Marvell 88E1111 Phy on my custom board.
