17 years agoAuto-Negociation fails between two Ethernet Marvell PHYs (88E1111)
Hello, I need to connect two PCIe development board via the Ethernet Marvell PHYs (88E1111) in order to validate an UDP solution (I'm using the TSE core). The thing is, Auto-Negociation between th...
16 years agoYes, you can adjust its internal registers using the MDIO interface. You may take a look at the 88E1111 datasheet to see what settings can be adjusted.
