ion_cortex's avatar
ion_cortex
1 year ago
Arria 10 GX dev kit-CvP Functionality
Hi everyone,
I’m running into a problem with my Arria 10 GX development kit and hoping someone here can help. I’m trying to get the Configuration via Protocol(CvP) working within the PCIe Hard IP. I am running into trouble when generating the *.periph.jic and *.core.rbf because the configuration device for my dev kit is not present in the options. (Check config_device_options.png)
Background:
  • I’m using Quartus Prime Pro (version 19.3) on Windows
  • The board is powered correctly and the USB-Blaster II is recognized without issues.
  • The JTAG chain is detected (see jtag_chain.png)
  • Trying to get the .jic into the flash memory
  • Following the user guide for Arria 10 CvP (check ug_a10_cvp_prop.pdf)
  • I am failing at the step when I start the flash over jtag with .jic
I’ve double-checked the MSEL pins and confirmed that the board is set to use AS x1 configuration.
Any advice or pointers would be appreciated, thank you!
    • ion_cortex's avatar
      ion_cortex
      Yes, I already was able to compile with CvP enabled the first time around. The problem I'm having is the specific configuration device on the Arria10 GX dev kit is not shown as an option when I go to convert my .SOF into the .jic and .rbf files. If you refer to the photos, they show what my JTAG chain looks like and the options for the configuration device and you can see that the 5M2210Z FPGA is detected in the chain and flash memory chip, but those aren't options within the other photo for configuration devices.
      Thank you,
      Hope this clears up any confusion.
  • JohnT_Altera's avatar
    JohnT_Altera
    If you are programming the jic file then you should be programming the flash that is connected to the Arria 10 FPGA and not the Max 5 device. Can you check if your MSEL setting on your board is set to Active Serial?
    You may refer to https://www.intel.com/content/www/us/en/docs/programmable/683227/current/default-switch-and-jumper-settings.html SW4 setting. You will need to set it to 010 as mention in Table 6.
    The default setting is Passive Serial.
    JohnT_Altera
    We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
